8 years agoAccelerator III
Why Parallel Redo Is Shutdown?
I am new to SQL Server Database, When looking in Windows event logs, I am seeing the following messages on an almost continuous basis -
Starting up database 'Database'. Parallel redo is started for database 'Database' with worker pool size [1]. Parallel redo is shutdown for database 'Database' with worker pool size [1].These messages happen at the same time and repeat continuously every second. Can someone explain what Parallel Redo is, and why it is continually starting and stopping, and causing the database to have to restart? The database is being used by an ASP.NET web application using Entity Framework, running on IIS. Windows Server 2016 Standard and SQL Server 14.0.100. Thanks & Regards Camillelola
