Mavis's avatar
Mavis
VB,how to Update the parent property in the onafterupdate event
I have an item type and a relationship
I want to calculate the sum of one of the columns of the relationship when the user presses the save button
and update it to the parent item.
If I put the method in the onafterupdate of the parent item, it will do an infinite loop
If I put the method in the onafterupdate of the relationship, when I update the value of more than one relationship, it will prompt me that 「Aras.Server.Core.ItemIsNotLockedException」...
'this is my parent onafterupdate method code
Dim inn As Innovator = Me.getInnovator()
Dim score_1 as Integer = Me.getProperty("score_1") ' parentItem.自評分數
Me.fetchRelationships("Performance_SelfScore")
Dim rs as Item = Me.getRelationships("Performance_SelfScore") 'get relationship
Dim rsCnt as Integer = rs.getItemCount()
If rsCnt < 1 Then
Else
   Dim i,self_score,sum_self_score as Integer
   sum_self_score=0
   For i=0 to rs.getItemCount() -1
      self_score = rs.getItemByIndex(i).getProperty("self_score")
      sum_self_score = sum_self_score + self_score
   Next
   Dim score1 as String = Me.getProperty("score_1")
   Dim successor_job_cname as String = Me.getProperty("successor_job_cname")
   Me.setProperty("score_1",sum_self_score)
   '↓↓The following code is what I use to update the parent property
   'The first way
   'Dim Self_Eval As Item = Me.newItem("Performance_Self_Evaluation","edit")
   '       Self_Eval.setAttribute("where","id ='" + Me.getID() + "'")
   '       Self_Eval.setProperty("score_1",sum_self_score)
   '       Self_Eval.setProperty("successor_job_cname","approve_mg")'day_auth.getProperty("approve_mg"))
   '       Self_Eval = Self_Eval.apply()
   'If Self_Eval.isError() Then
   '   Return inn.newError ("Performance_VB_test:Error Update Performance_Self_Evaluation " & Self_Eval.getErrorDetail())
   'End If
   'Second method
   'Dim Self_Eval As Item = inn.getItemById("Performance_Self_Evaluation", Me.getID())
   '       Self_Eval.setAction("edit")
   '       Self_Eval=Self_Eval.apply()
   'The third way
   'Me.setAction("edit")
   'Me.setProperty("score_1",sum_self_score)
   'Dim resultItem As Item = Me.apply()
   'Me.setAction("")
   score1 = Me.getProperty("score_1")
   successor_job_cname = Me.getProperty("successor_job_cname")
End If
Can anyone give me any idea?
  • Hi
    I was using another approach by hooking the method to on form populated event of the form
    Steps to be followed are
    Step 1: Create a Javascript method and add below code
    var innovator = new Innovator();
    var action = "edit";
    if(aras.isLocked(parent.item))
    action = "update";
    var parentField = getFieldByName("score_1");
    parentField.getElementsByTagName("input")[0].disabled = true;
    var rs = innovator.newItem("Performance_SelfScore", "get");
    rs.setProperty("source_id", document.thisItem.getProperty("id"));
    rs.setAttribute("Select", "self_score");
    rs = rs.apply();
    if (rs.isError())
    return rs;
    var sum_self_score = 0;
    var self_score = 0;
    for (var i = 0; i < rs.getItemCount(); i++)
    self_score = rs.getItemByIndex(i).getProperty("self_score");
    sum_self_score = sum_self_score + self_score;
    var currentScore = document.thisItem.getProperty("score_1","");
    if(currentScore != sum_self_score)
    var Self_Eval = innovator.newItem("Performance_Self_Evaluation", action);
    Self_Eval.setAttribute("id", document.thisItem.getProperty("id",""));
    Self_Eval.setProperty("score_1", sum_self_score);
    var Self_Eval = Self_Eval.apply();
    aras.uiReShowItem(parent.thisItem.getID(), parent.thisItem.getID());
    step 2: Add this method to Performance_Self_Evaluation form populate event
    Test and let me know if it works
    Thank You
    Gopikrishnan R
    • Mavis's avatar
      Mavis
      hi ,Gopikrishnan
        First of all, thank you for your reply!
        I tested this code, but I get the error message "parent.thisItem is undefined" or "menuFrame.populateAccessMenu is not a function".
        Later I changed the
        changed to
        "aras.uiReShowItem(document.thisItem.getProperty("id"), document.thisItem.getProperty("id"));
        There is still the error message "menuFrame.populateAccessMenu is not a function"...
        And it also seems to cause infinite loops when placed under this event
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi Mavis
        Can you try below steps
        Remove all the methods and event added as per my previous suggestion.
        Step 1: Create new C# Server Method and add below code
        int currentValue = Int32.Parse(this.getProperty("score_1"));
        Item relItm = inn.newItem("Performance_SelfScore", "get");
        relItm.setProperty("source_id", this.getID());
        relItm.setAttribute("select", "self_score");
        relItm = relItm.apply();
        int sum_self_score = 0;
        for (int i = 0; i < relItm.getItemCount(); i++)
        sum_self_score = sum_self_score + Int32.Parse(relItm.getItemByIndex(i).getProperty("self_score","0"));
        if(currentValue != sum_self_score)
        Item updateItem = inn.newItem("Performance_Self_Evaluation", "edit");
        updateItem.setAttribute("id", this.getID());
        updateItem.setProperty("score_1", sum_self_score.ToString());
        updateItem = updateItem.apply();
        return this;
        Add this method to Performance_Self_Evaluation item type server Events OnAfterUpdate event
        Thank You
        Gopikrishnan R
