bryan-riley's avatar
bryan-riley
1 year ago
Using Aras to Manage Aras Upgrade Planning, Test Plans, Test Records
I'm in the process to upgrade Aras, and I'm looking at the topic of Test cases and records. There seems to be some decent documentation about how to do this, it seems to be leaning on some external tool for this (looked around but things like TestRail is expensive... It appears to me to be a good use case for Aras to build in. )
Has anybody implemented an Aras Upgrade Planning / Testing Configuration?  Any suggestions or potential pitfalls you see with this?
Seems like if the structure was somewhat standardized, we could build a library of tests to share as a community, like this post suggested
  • eli_donahue's avatar
    eli_donahue
    I know some folks out there have created test management applications in Innovator. I'm unsure whether they use their solutions to manage Innovator test cases or just product tests, though.
    [emoticon:4ec4571d60f54e50910d7318d3f96ed7] Disclaimer: I haven't been personally involved in an official upgrade project in 10-ish years. If I make a statement that's inconsistent with your experience and/or the instructions of the upgrade team - I may be wrong. Always defer to Aras Support and the upgrade team.
    That being said, I'm gonna brainstorm.[emoticon:33306c418930400bac28808410f8ac8b]
    If I think it through "out loud", there are a couple of benefits:
    • Managing the test versions in Innovator sounds much easier than wrangling various Word docs with conflicting information.
    • Using Innovator instead of a 3rd party tool means you don't have to invest budget or train folks on another system - you're using what you already have and know.
    As for potential pitfalls:
    • You'd likely want to ensure production (or a specific instance) is your single source of truth for test plans - not the instance the QA user is testing - for two reasons.
      • During upgrades, you often test with a snapshot of your production data, not the latest data. If you need to update your test plans during the upgrade project, those data updates will not be reflected in the test environment.
      • If your test management solution tracks the test plans and the execution results for a specific upgrade pass, you probably want that data stored in an instance that persists - not the test instance that will be discarded in the next pass.
    Regarding the idea of a shared test library:
    I think it would be awesome if folks were willing to share some of their test cases to inspire others. The viability of a project like this would depend on a few factors:
    • Test case overlap (or lack of): Companies tailor the platform and standard applications in many ways to fit their business needs. If you look at the test cases from companies in different industries (ex: automotive, biotech, oil & gas, banking, heavy industries, high tech, etc.), how much do they have in common? I don't know the answer, but maybe some patterns would arise if enough folks contributed.
    • Test data: Test cases often reference items specific to a company and can't be shared (like Angela's example). The group's standard template would need an easy way to redact or obfuscate data while still preserving enough context to serve as a helpful example for others.
    • Legal stuff: How much are folks allowed to share publicly, and do their company's approval hurdles outweigh the benefit of sharing?
    I'm happy to support a project like this if there is interest, and it would improve the upgrade experience. Alternatively, if there are a few passionate folks but not enough buy-in for a library, the topic might be a neat guest blog subject.
      “Legal” is an important topic - both for Innovator users and for Aras itself!
      I believe nobody really wants to see their own test plan made public. And I don´t think Aras wants that either. I deliberately chose the “Tab Indicator” example above because I´ve already mentioned this feature about a dozen times in the forum anyway.
      Please note that we have the following sentence in the terms of use:
      "Licensee may not ....disclose, transfer or otherwise make available the results of any performance, capacity or functionality tests or any benchmarking testing of the Licensed Software to any third party."
      Therefore, I wouldn´t support a completely open test plan (similar to a GitHub community project). The information should only be available within a closed group.
      In my view, the key point is to have well-designed templates that users can then use to create their own test plans:
      Scope
      • General tests - What to check after install, basic navigation,...
      • Application-specific tests, PE, MPP, etc. E.g. describe what shall happen when you click the "Create new manual revision button" or create a ECO. User often have customized these features. But a test template could cover already 80% of the involved functionality.
      • Examples to show how to describe code customizations
      • Templates for partner products, especially those using DLLs
      • Templates for commonly used community products (if they represent a feature that is typically used as-is).
      • Test Federation and REST API connections. In best case we can create a standard of how to "simulate" these kind of external data.
      It would be very helpful if the Aras Update Team could also provide feedback on this idea - after all, they will ultimately have to work with our "brainchild"
      • bryan-riley's avatar
        bryan-riley
        So I gave it a rough prototyping, using three different ItemTypes (Aras Upgrades, Test Plans, Test Results)
        Upgrade ItemType has current / future version, link to Aras Project Schedule (could set up a project template), information about current / future server locations and hardware (thought about separating that off) and relationships with Test Plans and Documents
        Test Plan Page is linked to an Identity and PDF (or Technical Document) Instructions and has a relationship with 'Test Results, which is just the user, date/time, pass/fail, and comments.
        You would basically send the link to the Test Plan to the identities related, they open the instructions and log their results
        Unfortunately I built this in a temporary environment so it will be destroyed. But I have exported it so it could be recreated.
         [View:/community/cfs-file/__key/communityserver-discussions-components-files/10/Prototype-Upgrade-Manager.zip:131:75]
    Hi Bryan!
    Thanks for your interest in this idea! It´s maybe something to discuss in the upcoming TechSummit?
    Using Innovator to organize Innovator upgrades is an unexpected but great idea! What building technique or application would fit the purpose best?
    • Requirements Engineering?
    • Custom application?
    I assume this topic is related to manual test cases and not TAF. But of course, TAF users would probably also love to have a set of common test cases.
    In general, the tool should be easy to use for the people who have to write the tests.
    The official guidelines describe quite well how to organize the test plan. But from my POV, the guide doesn’t contain enough “realistic” examples. And it’s a bit over the top that each step starts with “A. Install Aras Innovator.” [emoticon:0f36700dfeb3494fa10d47dd9e1f90a1]
    In my upgrades, the team always showed more than enough common sense to deal with an "imperfect" test plan.
    So far I used MS Word, the individual steps looked something like this:
    My document contains general tests and specific tests for PE, MPP, code tree mods, custom stuff, etc.
    Word is not my favorite format for a test plan. I haven’t done an upgrade in a while.. I wrote these test cases long before a test plan was even a requirement at all. Today I would also include the names of relevant Methods, better (more detailed) description, better English, better images,...
