Super's avatar
Super
4 years ago
Upload Multiple files in a single click
Dear Aras Community.
How can I upload multiple files in Document Files Relationship tab. I have tried using a html code to add a file input to allow multiple file selection. but as file path is restricted or hidden, it is not possible for me to create a file item.
Any leads would help me great.
Thanks,
Super A.
  • Go to Edit > More, then select the Files tab. Select Upload: On the Upload a file screen, select Browse/Choose Files: Browse to the files you want to upload from your computer and use Ctrl/Cmd +select to choose multiple files.
  • Click on one of the files or folders you want to select. Hold down the control key (Ctrl). Click on the other files or folders that you want to select while holding the control key. Continue to hold down the control key until you select all the files you want.
  • In the forums I have found, the run 3 has good ideas for people to entertain and find interesting things.
  • Thanks for the solution @cmolnar65 it worked just fine for me as well!
  • did you manage to solve your problem because I have the same problem
  • I think it's good that sometimes you spend yourself playing run 3 those kinds of games as this serves as stress reliever but if its too much where in you spend much time playing than fulfilling you priorities then its really not a good idea.
  • Former Member's avatar
    Former Member
    Not applicable
    Open Google Chrome and click Customize / Control Google Chrome  Settings. Click on + Show advanced settings. Go to Privacy > Content Settings. In the Automatic Downloads section, select  clicker counter    Allow all sites to download multiple files automatically.the item you want to move (in List view, check the circle to the left of the item; in Tiles or Photo view, check the circle in the upper right corner of the tile). You can also select multiple items to move them together. In the Move to pane, browse to the destination folder, and then select Move  I have no problems with selecting multiple files to upload as I have set the multiple attribute. It is just when user wants to add more files to ...
  • Hi,
    when you use the insert relationship button you indeed only can insert one file. But have you seen that the files tab supports drag&drop? This way you can add tons of files at one :-)
