Hi Neil,
For most areas of the user interface, it's possible to add buttons like this using CUI. However, it seems this secondary menu hasn't yet been migrated to use the CUI data model. As an alternative, it would be possible to add an option to the context menu when you right click on an ItemType in the main grid.
This is possible through CUI following similar steps to the ones in this blog post and this corresponding community project. If you follow along with the blog post note that the item you edit in Step 2 will be different since you're editing a different area of the UI. Instead, you will want to find the Command Bar Section (the item that defines a general area of the UI) with the information below.
- Classification - Data Model
- Name - com.aras.innovator.cui_default.popup_menu_for_main_window_toc
- Location - PopupMenuMainWindowTOC
- neil_lindberg6 years agoCreator III
Is this post not in Forums > Development?
