Shin_Tanaka's avatar
Shin_Tanaka
Ideator II
Single sign-on to Aras Innovator using a proprietary authentication system
We have built a system that when you log in to a PC, that system can auto-login to multiple systems.
We want to use our own authentication system to automatically log in to Aras Innovator.
I would like some advice.
・Do you have any documentation that would be helpful?
・What information can I provide to get more detailed advice?
  • If you are looking for ParentVUE MHS Login? Then check here I have given step-by-step details for the Login ParentVUE MHS Portal including a screenshot. Before login into ParentVUE MHS, you should check some basics about ParentVUE portal uses, benefits, and how you can access it.https://parentvue-login.info/
  • Former Member's avatar
    Former Member
    Not applicable
    Thank!! for your kind comments.
      Former Member
      Not applicable
      facing a issue help me out? mobdro apk
    Former Member
    Not applicable
    Thanks for this. This worked exactly as expected. tellpizzahut
    • Shin_Tanaka's avatar
      Shin_Tanaka
      Ideator II
      What features did you work with?
      Please share to the extent possible.
  • Nice idea! Maybe you can use a REST call from an automatically run script to get a login token? There are a lot of REST API related blog posts in the Aras forum. Getting a login token is an easy task, it would be worth a try.
      Shin_Tanaka
      Ideator II
      We will try REST API. and please let me know again if anything comes up that you don't understand.
