5 years agoCatalyst II
Hi Travis,
you have to add values to the existing items that use these properties. As long as existing items contains a NULL value for your required property, you cannot change this setting.
If your Authoring-Tools is always the same, the easiest way would simply be a UPDATE in the SQL table directly. Of course a dangerous approach when you are not familiar with SQL. More save approach is via AML batch load script.
