Server logging for Aras 31
- 1 year ago
Hi Sudhir,
Try this instead:
CCO.Logger.LogError('message');I'll file a doc issue to update the programmer's guide with the right sample.
- 1 year ago
On R32 I'm doing it like this. Hope this helps
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:2e67c496-fc22-408a-ba1c-2b27b4e54496:type=text&text=var%20cco%20%3D%20%28%28Aras.Server.Core.IOMConnection%29%20serverConnection%29.CCO%3B%0Acco.Logger.Log%28LogLevel.Warning%2C%20%24%22Your%20message%20here%22%29%3B]
- 1 year ago
What we found was we had to add some config in the app setting file
Edit the
appsettings.jsonfrom the directory of your Aras Innovator installation e.g.(C:\Aras29\Innovator\Innovator\Server\appsettings.json) -
Update the LoggerConfiguration section from the
appsettings.jsonwith below code. -
"LoggerConfiguration": { "MinimumLevel": { "Default": "Debug" }, "WriteTo": [ { "Name": "File", "Args": { "path": "Logs\Aras_Log.txt", "rollingInterval": "Day" } } ] },
The log file mentioned here was later used by the logger
pls note you will have to restart IIS
