Barnali's avatar
Barnali
Revert to previous Revision
I have a part which was in released state and revision A. After making some changes, it has moved to revision B and preliminary state. The assemblies related to the part show revision A.
I want to revert the part to revision A with released state so that when I click on Views-->where used, I can see all the assemblies related to it.
Thanks,
Barnali
    • Nathan_H_'s avatar
      Nathan_H_
      Accelerator I
      I was able to Purge by selecting Edit > Purge.  It deleted the current version & when I searched for the document I found the previous version.
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi Nathan
        Purge will delete latest generation not the latest revision. you need to purge till it reach the required revision.
      Gopikrishnan
      Accelerator II
      Right click on the part and select Purge action is not working ?
  • Hi Barnali
    You can try purge action in Part B revision (right click and select Purge this revision option). This will bring the part to previous generation. (you can try purge multiple time to bring it to A revision)
