6 years agoCatalyst II
it should be possible for you to modify the properties.js.
You maybe can use code from this community project for your modification.
https://github.com/ArasLabs/updated-properties-dialog
I am not sure if the project is fully compatible with SP9, but for your use case you shouldn´t need the complete project, so it´s worth a try.
keipidesu
6 years agoIdeator III
Hi Angela!
Apologies for the late reply. Thank you so much for this info!
