Stefano_Corti's avatar
Stefano_Corti
25 days ago
Problem enabling user for Project/program TOC: PresentationConfiguration already exists
  I have this problem:
When I try to add a new user in the TOC access I have the error:
I can't understand where is the problem, the presentation configuration is empty
Thanks
Stefano
    • Stefano_Corti's avatar
      Stefano_Corti
      HI,
        is different because that time I had an entry in style client. Deleting it as you suggested it worked.
      This time style client is empty but I have an error anyway
      • AngelaIp's avatar
        AngelaIp
        I assume the PresentationConfig exists already...
        ...not in your "Client Style" tab, but as independent item in the "Presentation Configuration" ItemType.
        You probably got this item when installing the PM app. Look at the package used for PM. If it contains something for the Presentation Config, than this might be your problem.
