BoxCoder
6 years agoIdeator II
Where can I find more information about this purge option? Thank you for your response.
Gopikrishnan
6 years agoAccelerator II
Navigate to Design --> Parts
Search for the part you want to revert
Right click on the part and select Purge
- BoxCoder6 years agoIdeator II
our instance does not have this purge option, but I appreciate your response and thank you. What version of ARAS are you on?
- Gopikrishnan6 years agoAccelerator II
Hi BoxCoder
I'm able to see this option in both ARAS 11 (Name: Purge) and 12 (Name: Purge This Version). I guess this is in built action available similar to get and edit. You can try this option using below AML query also
Run this query in nash or innovator admin tool. Change ID in below query.
<AML>
<Item action='purge' type='Part' id='7AADF748B0CE49E1A8ADA82DA0AEB961'>
</Item>
</AML>Thanks
Gopikrishnan R
