Jan's avatar
Jan
Ideator II
4 months ago
Navigate tab --> Workflow
In an item, when i click on Navigate option and click on workflow, then i get the error as following: Error: Item Type with name Null was not found.  This happens when new revision of an it...
  • alderaan's avatar
    alderaan
    2 months ago
    Hi, I am sorry it could not help. For me what I have written above is what caused the issue. You may have a different issue then.
    You might need to investigate the error in browsers Developer Tools (F12). Usually it shows the error in console output or you can see the faulty request in Network tab. Then you would try to set breakpoints and analyze further.
    Also you can try to contact Aras support.
