- Former MemberNot applicable
In Tech Docs, there is the Add Link feature which allows you to select a section and create a vidmate hyperlink. Is there anyway to style the link with information from the target?
Hi!
I ran into a similar issue when I needed to manage multiple lifecycles for an item type. I created a custom server method to select the lifecycle based on conditions like the item's state or properties. For example, if the state is "conditionA", the method will return lifecycleA, otherwise it will return lifecycleB. This makes the code cleaner and more flexible. Be sure to test it thoroughly to make sure everything works as expected.
