Your Workflow seems to do "something" automatic, but it´s not easy to tell.
1. Do you have fully build the Workflow by yourself? Do you use Workflow Methods?
2. Is your Workflow connected to a Lifecycle?
3. Do you just get the error message when adding a relationship, or also in other scenarios?
4. Is your Relationship ItemType the same as your parent ItemType, or do you link a different ItemType?
- Mickey_San_Miguel5 years agoIdeator III
Hi there!
Thanks for you response. I've added some details about the questions you had.1. Do you have fully build the Workflow by yourself? Do you use Workflow Methods? I copied an existing workflow which was close enough for what we needed for me to make some modifications on. .No workflow methods.
2. Is your Workflow connected to a Lifecycle? Yes, the ItemType (manufacturing part request) contains a lifecycle and workflow.
3. Do you just get the error message when adding a relationship, or also in other scenarios? The error message happens when I try and create a new manufacturing part request. It allows me to fill out the form, although once I try and save my request, It spits out the "ItemIsLockedException" error.
4. Is your Relationship ItemType the same as your parent ItemType, or do you link a different ItemType? See Screenshot
