asebastian
7 years agoCommunity Manager
Hi Gkarasuser,
Would you mind showing me a screenshot of the relationships tab of that specific workflow activity? I would also recommend checking the path you're taking, to ensure that there are no pre/post methods associated with the path. This error is commonly thrown when you're attempting to assign an item to another Item using item.setPropertyItem(), which leads me to believe there is some method being called in relation to this activity.
AJ
