keipidesu
7 years agoIdeator III
How to use the node.js library in getting file paths, etc.
Hi! I found a node.js library inside the Client folder "javascript/dojo/node.js". Question is how do I use it properly?
I want to use the 'fs' and 'path' modules to get the files and paths info, but it seems like Aras has a different syntax for this.
So far I managed to write the code below on my JS program, but I still don't know what to write inside it without getting errors.
define("dojo/node", function(kernel, has, require){
Any help, insights are appreciated.
