- GopikrishnanAccelerator II
Hi Dkahraman
Yes, it is possible to have different workflow for different documents. You can create different workflows and can have action submit to Workflow from item which will open a form where user will select the workflow and you need to instantiate the workflow dynamically. Instead of action, you can also run the method on selection of document classification to achieve this.
- dkahramanCreator I
is there any sample code? I've tried something else but it's not working.
Hi Dkahraman
I cannot able to share the method here as the size exceeds the allowed limit and it is marked as SPAM.
