7 years agoCommunity Manager
There are a couple possible solutions to this, but by default, there isn't yet a standard way of configuring visible properties per relationship.
One solution would be to create a custom Grid item for the relationship. You can configure the viewable properties under the Grid Column relationship tab. However, these custom Grids are expected to be view-only, so they may not fit your use case.
Another possible solution would be to write a method that would automatically update the Preference item corresponding to your users. Preference items contain a relationship tab called Relationship Grid Layout. The items in this relationship specify what columns should be displayed to the user when they view a specific relationship grid. One thing to note is that from a relationship grid, a user can right-click on a column header and select Insert Column to add any columns that may be hidden. This solution will not prevent users from inserting the columns you choose to hide by default.
