Michael_Rodriguez's avatar
Form "Unused Properties"
I have an ItemType called Zed that has several properties that do not have Data Sources, yet when adding to the form via "Unused properties", the Data Source is populated, cannot be removed.  Warning message stating Data Source is required.
Note: Both fields are Required Fields, both are text fields
Example:
Name = name
Label =  Name
Data Type = String
Name = item_number
Label = Zad Drawing Number
Data Type = String (will be Alphanumeric)
Any suggestions??
-Marz
  • Former Member's avatar
    Former Member
    Not applicable
    I experienced the same thing. Don't have any idea what's behind this.
    Former Member
    Not applicable
    I also encountered this once.
  • Thanks for the blog loaded with so much information. Stopping by your blog helped me to get what I was looking for.
    play snake
