2 years agoCatalyst II
which port do you use? In my case only port 587 worked for SMPT emails, not port 465 and of course not 25. In my case in the past also some firewall settings blocked the emails.
- Geerthana_Moorthy12 years agoIdeator III
Same , I am also using port 587.
I remember I used a simple test Method for checking the SMPT server connection and I always got the STARTTLS error message. But sending emails from Innovator it self worked.
Does it work when you use the unsecure variant without encryption (just for testing)?Have you asked Aras support already? As you mention Aras 22 you obviously have a subscription.
I changed "disabled_operating_parameter" tag to "operating_parameter" in config file and then mail log is generated in Innovator > Innovator > Server > Temp folder..
