7 years agoCatalyst II
You could use this community project: https://github.com/ArasLabs/auto-workflow-assignment
Assignments are set, as soon as an Activity is active. So you do not use the predefined assignments in the workflow.
The example defines assignments by reviewers that are set in the change process. Bu instead of using assignments by reviewerr, you can also choose the assigments by classifcation. This way you can use the same workflow, but can achieve more specific assignments.
dkahraman
7 years agoCreator I
thank you very much, I will try that.
Duygu
