Ryan_zh's avatar
Ryan_zh
11 months ago
Error: Failed to login in (Aras Innovator 14) cause by 502.3 - Bad Gateway
Hi community, I have installed Aras Innovator 14 in my computer. And I have installed all .net application. Using SQL Sever 2022, and create DB after installation. When I access to http://...
    11 months ago
    Sounds like missing C++ Redistributable. Your image only shows outdated stuff. I don´t see any version that is newer than 2013.
    Check out this video - 84 likes don´t lie: https://www.youtube.com/watch?v=A5QEtOO86ik
    Error 502.3 is not explicitly mentioned in the video, but we have Error 502. I still use this guide for each modern Innovator installation. Here and there you need to use a different version of something, but the rest is the same.
    Remarks: If you have SQL Server 2022, use SQL Server 2022.
