dkahraman's avatar
dkahraman
Dynamic Workflow for DCO
I want to have multiple workflows for different DCO subclasses. I've seen a code here but I can not work with it.
the code is :
switch (classification)
case "DCO I":
wflMapName = "Express DCO-I";
break;
case "DCO II":
wflMapName = "Express DCO-II";
break;
Item wflMap = inn.getItemByKeyedName("Workflow Map",wflMapName);
Item wfl = this.instantiateWorkflow(wflMap.getID());
  • Hi Dkahraman
    Please try using the below method
    string workflowName = "Express DCO-II";
    Item workflowMap = this.newItem("Workflow Map", "get");
    workflowMap.setAttribute("select", "id");
    workflowMap.setProperty("name", workflowName);
    Item result = workflowMap.apply();
    string mapId = result.getProperty("id");
    Item workflowProcess = this.instantiateWorkflow(mapId);
    workflowProcess.apply("startWorkflow");
    return this;
    I have a package uploaded here. You can import it using import tool.
    [View:/cfs-file/__key/communityserver-discussions-components-files/10/DynamicWF_5F00_DCO.zip:68:89]
    Once import is done, re-login to application, create DCO, select DCO type in drop down that will assign workflow dynamically.
    Thank You
    GK
