I think it´s possible to delete all elements of type 'Part_BOM' which has the source_id of your parent Part.
<Item type="Part_BOM" action="delete" where="[Part_BOM].source_id='123456....'"></Item>
Not tested! Use with care :-).
I think I am close, I have the following:
<Item type="Part BOM" action="delete" where="Part_BOM.source_id='@1'"></Item>
The parent part number I am reading from a file, first column. I am not getting errors during execution, but the part BOM is still there (the command did not delete the BOM, I can still see it in the part). I think this line makes perfect sense so I will look into it again and see if I missed anything. I also tried the following script:
<!-- To delete a complete BOM, round 2, no errors but not working -->
<Item type="Part" where = "item_number = '@1' and is_current = '1' " action="edit">
<Relationships>
<Item type = "Part BOM" action = "delete" where="Part_BOM.source_id='@1'"></Item>
</Relationships>
</Item>
Should I change my approach, or am I on the right track?
- Gopikrishnan7 years agoAccelerator II
Hi Pmateo
It should be on opposite way. You need to use the related_id. (Source ID is ID of Parent Part and Related ID is ID of Child Part)
Example:
Parent1 --> Child1
Parent2 --> Child1
If you want to delete Child1 in Parent1 and Parent2. Use below query
<AML>
<Item action='delete' type='Part BOM' where="[Part_BOM].related_id='773D6786B7DE48439F373F59'"></Item>
</AML>Here Related ID is ID of the Child1.
Hope it helps.
Thank You
Gopikrishnan
Hi. Thanks a lot for the suggestion. Even when I run the query as you specified I don't get any errors, but the BOM stays in place. I am starting to believe something is preventing me from deleting BOM using queries (manually I can).
If I understand correctly, the query you sent would delete Child1 everywhere right? If it belongs to 10 parents, then all 10 parts will have Child1 deleted. I was trying to go the other way around, I want to delete all child parts from a given parent, regardless of how many there are in one go; that's where I got the query <Item type="Part BOM" action="delete" where="Part_BOM.source_id='@1'"></Item> but exactly as when I ran yours: no errors show up but the BOM doesn't change. I will re-read the documentation in the developers forum and give it another try.
Hi Pmateo
Yes, it will delete Child1 every where it is used and your query is correct and it should delete all bom in parent/ May I know using which account you are running the query ?
Also try with get query instead of delete in AML studio first. If it works, can you run the delete query in AML studio first and see the result.
<AML>
<Item type="Part BOM" action="get" where="Part_BOM.source_id='@1'"></Item>
</AML>
Thank You
Gopikrishnan
