AdityaSaraff's avatar
AdityaSaraff
4 years ago
Create Server Logs
Dear Aras Community,
I have the following problem. I want to activate the server logs. To do this, I set <operating_parameter key = "debug_log_flag" value = "true" /> as described in the instructions and restarted the server. The following error occurs when I want to log in ( Could not find a part of the path 'D:\ARASInstances\KPEC\Innovator\Server\logs\2021-12-23-11-04-59-26.xml'). Can you please help me?
Best regards
  • And if you just open that document and what you're going to type at the very top of the document is a full stop or a period. And then the word log in uppercase. So i'll just type the word log.
    Target Gift Card Balance
  • Follow these following steps, hopefully it will help you.
    1- In the left pane of the Console, expand Diagnostics and select Log Files.
    2- In the Log Files table, select the radio button next to the server instance log file you want to view.
    3- Click View.
    4- Select the radio button next to the log record you want to view.
    5- Click View.
    The page displays the server log file entry, including the probable cause and any action you can take to remedy an error that a message describes.
