8 years agoAccelerator III
Hi Chris,
Thank so much for your answer.
I try to many times same as the link but it seems not work. My Aras quite different and more complicated than in link.
I used “Create New Revision” on source to up version and it run well but it depends on Aras setting to access to edit the Part that I want to revision.
Recently I met a situation, I can not up revision because of Aras config not allow edit Part which one in state "Released".
I try to use Tool - > Admin -> Reset Item Access. It allow edit although Part is in state "Released".
I don't know where setting to prevent edit Part when it in state "Released".
Please show me if you could.
Thank a lot.
Vivian.
