asebastian
7 years agoCommunity Manager
Hi Chris_Smoke,
Aras provides the import and export tools, which will allow you to move your customizations, without moving your whole DB. These tools can be found here, or in the CD image. I've written two blog posts going over the basics of packaging, as well as one which goes over a situation similar to your use case.
Following these guides will show you how to move only your customized ItemType, without all of your test data.
AJ
