8 years ago
ArasLabs/collab-folders
  Hi, I am trying to use ArasLabs/collab-folders  (github.com/.../collab-folders) with Aras Innovator Version 11.0 SP12  Build: 6920 I have importing all packages including optional successfully.  And also copied codetree folder. And I can sign-in without any issue. But I get the following error, whenever I try to open folders related views. Cannot load grid configuration '' ! ERROR: - Failed to get the tgc_Apply to Item Types ItemType. Am I missing something ? Any help is appreciated. Thank you so much.
  •   From GIT, I am finding that SP12 is not supported yet. Could you please let us know the expected date or plans for migration ? Thank you.
  •   Hi, I am finding the same issue with version 11 SP 11 too. Issue is coming from \Innovator\Client\Solutions\CommonUtilities\javascript\CommonBaseTreeGridCfgHandler.js and the following bold line fails. Seems it fails to get configuration item for itemtype. var configItem = top.aras.newIOMItem(""); configItem.loadAML('<Item type="'+this.applyToItemType+'" action="CommonBase GetGridConfigItem" configName="'+configItemName+'" />'); configItem = configItem.apply(); if (configItem.isError()) { top.aras.AlertError(top.aras.getResource("CommonUtilities","commonUtilities.message.cannot_load_grid_configuration").format(configItemName)+" - "+configItem.getErrorString()); return false; } this.configItem = configItem Please help.  Thank you.
  • Found out all by myself. Sharing here for benefit of others. Works for both Version 11 SP11 and SP12 too. Although this instruction is part of installation notes, it was not explicit. Go to variables and set values for the following: tGridCfg cFolder Client/Solutions/ItemFolders/xml/cFolderStructureConfig.xml tGridCfg cFolder Template Client/Solutions/ItemFolders/xml/cFolderStructureConfig.xml tGridCfg Project Client/Solutions/ItemFolders/xml/cFolderStructureConfig.xml tGridCfg Root Folders TOC Client/Solutions/ItemFolders/xml/cFolderStructureConfig.xml tGridCfg User Folders TOC Client/Solutions/ItemFolders/xml/cFolderStructureConfig.xml
  • I'm receiving errors with Ara. IOMLogin.aspx Either IOMLogin.aspx is not setup to use intergrated Windows authentication or the authentication failed. Another user has Enovia, but Aras plugin does not work. I just started at this company and first time being exposed to Ara and Catia. Please help!
