Is there a way to sort rows/content in alphabetical order in tree grid view ?. We have a relationship tab where we add the relationship items , using tree query definition we build a tree grid view b...
I remember I asked for this feature around 3 years ago and Aras said it´s a great idea! (TGVs were still a pretty new feature at this time). Never heard anything since then :-).
Which Innovator version do you use? Do you have tested the "Sorting" menu inside the Query Definition?
Translation: Right click -> Edit Query Element -> Sorting (or similar text).
As far as I remember the feature was grayed out in the past or didn´t sort reliable. I am not sure anymore. I have not tested if it works now.
So depending on your Innovator version, there is a change that sorting was implemented. It was definitely not a feature present in previous versions (11SP15,...). Would be happy to know your results!
In latest versions of innovator, yes you can click on column headers in TGV and it will sort ascending or descending. I have used it for ARAS 12SP08. Not sure in which version this was introduced
