sehajpalsinghjIdeator I9 years agoadd a method using C#Hi, I am new to this domain.Is it possible to add a method to an item type using C sharp code? If so, could you give an example.
Yoann_MaingonAccelerator I9 years agoYes you can. Look at our programmer's guide : www.aras.com/.../Aras Innovator 11.0 - Programmers Guide.pdf
Recent DiscussionsRelease date of the next open release?SolvedRelease 36 Bug Fix: Search Grids Remain Blank and Strange Horizontal Scroll BehaviourCreating a package using the innovator adminFMEA MasterHow is the Template field in the consultation Document used?
