Hello, @Angelap, Did you find a way to "customize" the "Where Used"?.
Reading this post, they indicate, I think, how to do it, but I don't see the "keyed name order" column in my Itemtypes. I don't know if my version of ARAS is another or I don't know...
Hi Meupe,
I think your post were blocked by the spam filter some time ago.
So far I don´t think we can customize the ootb "where used".
Regarding keyed_name and just meant the regular keyed_name properties in the itemtype. But it´s not the best solutions to edit the keyed_names just to get a more detailed WhereUsed view. The keyed_names are used in multiple ways, so it´s not a good solution to add long properties like "name" to them.
One workaround is to use a custom TGV for a WhereUsed view.
- team_aras_meupe_com3 years agoCreator III
Hello Angela, yes, i was blocked by spam filter, for a weeks............
Thanks, I already found the "keyed_name", but it makes a little mess in the searches and so on, it is not a viable option.
I have read a lot about the use of TGV, but unfortunately in my version of ARAS (11 sp9) it was not implemented yet. I am struggling in the company to see if they update at once to the latest version of ARAS, since our version is very old and there are many new things when it comes to programming that we could use.
In these weeks of "ban", many doubts/problems have arisen, but since I couldn't write in the forum........... I'll ask them!!, :)
Too many thanks!!!!
Nearly everybody was blocked by the spam filter after the last forum update. I was in contact with Aras myself. They improved the filter, but I guess it took them some time to separate all affected people from the spam bots (there are a lot...). If it happens again, directly write them.
And don´t forget: The reason your company has a subscription is, that you get proper support and don´t have to use the forum. Your company pays for this service.
You can ask them each question you normally would write in the forum. This Where Used question is perfect for support. Seriously, how many subscribers do you see in the forum? Just a couple, cause the rest asks directly (or is still banned :) ). The best solution is to use both options (forum + support). Support is great for correct fast answers to general questions. Forum is best for solutions that the support is not allowed to recommend or are bit experimental.
You can also ask for tips regarding update and how to limit the worries of your company. They have done this before. If still in doubt, I also offer a consulting service where I can share tips that I wished Aras would have told me before doing update :).
