Yoann_Maingon
9 years agoAccelerator I
that would be the keyed-name
In the part itemtype defintion in the properties tab, if you look at the column "keyed name order" you will see that it has a 1 on the line item_number. Just add a 2 in the same column but on the "name" property line. And that will be it.
