Hi Jenli,
Can you confirm that you're able to upload a file manually?
AJ
Hi AJ,
Thank you for being here for our issue. For your question that I am able to upload to CAD File by using "Select New File" button on Manage file dialog with no problem. Please see the screenshot below.
I also put the default Vault pattern information and VaultServerConfig.xml file that you may need as following below, I am confused about any problems with the settings over there. thanks.
Best regards,
Jen Li
- asebastian6 years agoCommunity Manager
Hi Jen,
Could you please post a segment of the code you're using to attempt to upload files? This will give us better insight into what is actually happening in your environment,
AJ
- Jenli6 years agoCreator I
Hi AJ,
Below is the piece of code of getting specified file we need then upload the file into system.
var item = parent.thisItem;
var NativeFileID = item.getProperty("native_file");
var qry = item.newItem("file", "get");
qry.setAttribute("select", "filename");
qry.setProperty("config_id", NativeFileID);
var res = qry.apply();
var file_name = res.getProperty("filename");
var filePath = "C:\\temp\\" +file_name;
var item1 = item.newItem('File', 'add');
item1.setProperty("filename", file_name);
item1.attachPhysicalFile(filePath);
var item1 = item1.apply();
if (item1.isError())
top.aras.AlertError( "error:" + item1.getErrorDetail());
else
return "Success!";
Thanks a lot!
Best,Jen
It seems that once the code run into item1.attachPhysicalFile(filePath), then it get the vault error I sent to you. Thanks.
