Hi Jenli,
Can you confirm that you're able to upload a file manually?
AJ
- Jenli6 years agoCreator I
Hi AJ,
Thank you for being here for our issue. For your question that I am able to upload to CAD File by using "Select New File" button on Manage file dialog with no problem. Please see the screenshot below.
I also put the default Vault pattern information and VaultServerConfig.xml file that you may need as following below, I am confused about any problems with the settings over there. thanks.
Best regards,
Jen Li
- asebastian6 years agoCommunity Manager
Hi Jen,
Could you please post a segment of the code you're using to attempt to upload files? This will give us better insight into what is actually happening in your environment,
AJ
Hi AJ,
Below is the piece of code of getting specified file we need then upload the file into system.
var item = parent.thisItem;
var NativeFileID = item.getProperty("native_file");
var qry = item.newItem("file", "get");
qry.setAttribute("select", "filename");
qry.setProperty("config_id", NativeFileID);
var res = qry.apply();
var file_name = res.getProperty("filename");
var filePath = "C:\\temp\\" +file_name;
var item1 = item.newItem('File', 'add');
item1.setProperty("filename", file_name);
item1.attachPhysicalFile(filePath);
var item1 = item1.apply();
if (item1.isError())
top.aras.AlertError( "error:" + item1.getErrorDetail());
else
return "Success!";
Thanks a lot!
Best,Jen
