Kriengsak_P
7 years agoIdeator I
Unable to request license key for innovator 12.0
I try to request license many time for Aras innovator 12.0 but it show below message
erver Error in '/Support/LicenseKeyService' Application.
The operation has timed out
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.WebException: The operation has timed out
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Stack Trace:
[WebException: The operation has timed out] Microsoft.VisualBasic.CompilerServices.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags) +477 Microsoft.VisualBasic.CompilerServices.NewLateBinding.CallMethod(Container BaseReference, String MethodName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, BindingFlags InvocationFlags, Boolean ReportErrors, ResolutionFailure& Failure) +316 Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn) +142 Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn) +405 LicenseKeyService.WebForm1.ExecuteTransaction() in C:\Aras\Visual Studio Projects\LicenseKeyService\LicenseKeyService.aspx.vb:122 LicenseKeyService.WebForm1.Page_Load(Object sender, EventArgs e) in C:\Aras\Visual Studio Projects\LicenseKeyService\LicenseKeyService.aspx.vb:48 System.Web.UI.Control.OnLoad(EventArgs e) +106 System.Web.UI.Control.LoadRecursive() +68 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3785 |
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.3282.0
