Bertie's avatar
Bertie
Transfer from Structured Framemaker (Adobe) to Aras Tech Docs
We are using Adobe Framemaker to make our technical documents. Does anyone have experience how to transfer from adobe framemaker to aras tech docs easily?
  • As far as I know Framemaker documents can be exported as xml files. It should be possible to transform/translate the xml format to the required TechDoc Format. When you have the correct structure needed for TechDocs, you than just have to rebuild the stylesheet.
    But this task depends on the complexity of your documents.You should rebuild one of your Framemaker documents in TechDocs first, so you can compare the xml structures.
