Gopikrishnan
6 years agoAccelerator II
Hi Jaiganesh
Ensure that SQL Server is running in services.
Step 1: Press Windows Key + R (to open run)
Step 2: Type services.msc
Step 3: Search for SQL Server
Step 4: Right click and select Start (If not running)
Thank You
Gopikrishnan R
Jaiganesh
6 years agoIdeator I
Hi Gopi,
Thanks for your reply.
Yes, SQL Server is running & I'm not able to login still.
When I try to login to Aras (using admin/innovator),
it takes sometime and finally shows the below message in the login screen:
"The operation was canceled."
Any input would be appreciated.
Regards,
Jai
