9 years ago
Self Service Reporting run report
Hi all, I've a strange issue with self servivce reporting. I've created a new report into my ARAS SP8, and it works fine, I can run the report from myReports, but if I logout from Aras and login again in a second time and try to run or edit my report this doesn't work (blank window) but if I go to self service reporting under the administration menu and try to create a new one then also my previous report can be run. I'm not able to understand how if I try directly to run the report it doesn't work while it works only if before I open the creation of a new report... thanks
  • I noticed the following issues with self service reporting. Is this fixed with SP9? In the viewer of the report, not all of the results are available to view Also when trying to export to excel or PDF, to view all results, the boolean values translate to blank.
  • Hi, The unexpected behavior you are seeing with Self Service Reporting has been fixed in SP9. I recommend contacting support for information about upgrading to SP9 in order to resolve this behavior.
