eli_donahue
9 years agoCommunity Manager
Hi shwnhlgn,
You can add a filter on the is_current property to view data for only the current version of an item.
- In the Self Service Report editor, click the Filter tab.
- In the pane on the left side, select the ItemType you want to filter.
- Once you select the ItemType, you will see a list of properties populate below the data structure in the left pane. Select the is_current property and click the Add to Report button.
- Set the filter criteria for the is_current property to Equals.
- Set the filter value for the is_current property to 1.
- Select the Preview tab to confirm the report results.
- Be sure to save your report before closing the Self Service Report editor.
