Amitosh_Tripathy's avatar
Remove Relation from older generations
My CAD is in Rev A Generation 1
It was added to a part on Rev A Generation 2, and was removed in Generation 3 of the part. Currently part is in Generation 4.
I want to delete the CAD, but it gives me error : "
<faultstring><![CDATA[CAD cannot be deleted. It is used in Part CAD related_id CAEBB682F6164224962E61BBE49411DC.]]></faultstring><detail><af:legacy_detail><![CDATA[CAD cannot be deleted. It is used in Part CAD related_id CAEBB682F6164224962E61BBE49411DC.]]></af:legacy_detail><af:legacy_faultstring><![CDATA[ItemMethods: PurgeItemEx2: Referenced items found (type=Part CAD:CAEBB682F6164224962E61BBE49411DC)]]></af:legacy_faultstring>
Note : CAD relation is Hard Fixed out of the box.
How do I take care of deleting such related items?
The CAD item shows the part in UI(field name : part) which is HTML, and is a link to the part Rev A Generation 2. Can I may be create admin form to allow removal of relation from UI? Or there is a cleaner way to do it?
  • Hi
    You can use AML Query to delete the relationship first and delete the CAD item.
    <AML>
    <Item action='delete' type='Part CAD' where="[Part_CAD].related_id ='1111111111111'">
    <behavior>float</behavior>
    </Item>
    </AML>
    Here Related ID is ID of the CAD item
    • Amitosh_Tripathy's avatar
      Amitosh_Tripathy
      I wrote a method with same logic, which I can run as server method and give the guid there
      I also made Part CAD relation available in TOC to do the same by Admins
