9 years ago
relationship grid layout
Hi I am using Aras 11SP9, browser  Chrome 57.0.2987.133 When I  want changed the order of columns(relationship grid layout), I dragging the  column heading. It work on the IE 11 and Firefox, but not work in the Chrome. How to fix it? Thanks,
  • Hi, I just tested it on the same Aras version and same browser version and it works ! is it still not working for you?
  • Hi Yoann Yes, I have the same problem. And I test 3 PC, all have the same issue. I can  dragging the column heading, but it can't save to Preferences relationship grid layout. My Client OS is Windown 7 SP1, Server Win 2008 R2 , Database SQLServer 2008 R2 Thanks,
  • oh so that's a different problem, you can drag but it doesn't save. So the next time you load the same grid it is back to the default column organisation?
  • eli_donahue's avatar
    eli_donahue
    Hi mark_chen, I ran a quick test in my local instance. If I rearrange the columns in a relationship grid, close the item and then reopen it, the columns are in the default order. However the custom column order was preserved if I rearranged the columns, logged out of Innovator and logged back in. I hope this workaround helps. Eli
    • Suttermireles's avatar
      Suttermireles
      What is CSS Grid Layout? A CSS Grid is used to divide a web page or container into columns and rows, along with the ability to position and size the building block elements based on the rows and columns we have created in terms of size, position, and layer.
