dkahraman's avatar
dkahraman
8 years ago
QMS R2
Hi ! I installed QMS R2 to SP9. After installation, I am just seeing Quality Document Item Types in the innovator. Is there a way to uninstall and re-install all over again? thanks
  • eli_donahue's avatar
    eli_donahue
    Hi Duygu, There isn't any quick and easy way to uninstall a package that was installed with Aras Update. However, you should be able delete the QMS Variable from the database and reinstall. To find the Variable, go to Administration > Variables in the TOC. Then search for "Quality Management System" and delete the item. Eli
