Hello Guys,
Can you suggest me solution for Promotion issue for below life cycle sate create state?
Some time user not able promote(Error is No promotion is available ) lifecycle sate for ...
Do you have really assigned this LifeCycle to your item? Do you use alternative LifeCycles?
Do you have changed the Lifecycle a couple of times? Maybe even removed and then inserted the same state?
Have you already tried the "Resett LifeCycle" / "Set Default LifeCycle" action? These two are typically used to repair a corrupted lifecycle on already existing items.
Does your users have update permission for the item?
Also check in your map if the identities really fit the shown pathes. Inside the editor the labels sometimes jump around and what you see might be wrong.
