I am using Version: 11.0 SP14 of ARAS.
I have a method at OnBeforeNew client event of Realtionship. To add a relationship item, a search dialog box is opening. I want to get the details of the selected item in search dialog box. let me remind that the event is ONBeforeNew.
Could you also elaborate on what you want to do with the details of the selected item once you have them? For example, are you trying to do some validation so that the user can only add certain items as a relationship?
- shubh2603936 years agoIdeator I
Once I have the item I need to check that the selected item should not be present in any other Document relationship of Part. If it is not present anywhere else then only I sholud allow it to attach in the Document relationship.
- Chetanasing_Hajare4 years agoIdeator I
I am also working on similar use case. Any solutions for the above mentioned use case.
- Gopikrishnan4 years agoAccelerator II
Hi
Not sure your use case is getting the selected item in search dialog or not allowing user to select the document if it is used in any other parts.
If second is the use case, you can add custom search filter while opening the search dialog
