Could you provide some more details on what you're ultimately trying to accomplish? Also, could you let us know what version of Aras Innovator you are using?
I am using Version: 11.0 SP14 of ARAS.
I have a method at OnBeforeNew client event of Realtionship. To add a relationship item, a search dialog box is opening. I want to get the details of the selected item in search dialog box. let me remind that the event is ONBeforeNew.
- christopher_gillis6 years agoCommunity Manager
Could you also elaborate on what you want to do with the details of the selected item once you have them? For example, are you trying to do some validation so that the user can only add certain items as a relationship?
- shubh2603936 years agoIdeator I
Once I have the item I need to check that the selected item should not be present in any other Document relationship of Part. If it is not present anywhere else then only I sholud allow it to attach in the Document relationship.
- Chetanasing_Hajare4 years agoIdeator I
I am also working on similar use case. Any solutions for the above mentioned use case.
