Hello Ashok,
I don't think its configurable. Please check out Command Bar Item searchview.commandbar.default.display.preview.properties
Thanks,
Jayraj
you can customize nearly everything in Innovator. But sometimes not in the database directly.
This side pane can be customized in the codetree. I far as I remember, these two files are involved:
..\Client\javascript\ui_methodsEx.js
..\Client\xml\ui_resources.xml
Just look for entries called ItemInfo or item_info and add your own elements the same way as the existing ones.
Write a test case for this codetree change when you are an subscriber. This is a typical codetree change that might be overwritten by the update team. So ensure to tell them that you have changed these files.
- Ashok_Yadav5 years agoCreator II
Thank you Jayrajvh it's working
