Hello, I'll test it and get back to you soon. Thank you.
My basic requirement is to be able to find a final parent article from two shared child articles. I'm in the first child article with my related TGV. Example, I am in the bearing article and I enter in variable the name of the article 2 a shaft and I want to find the motor which uses its 2 components).I created a variable to dynamically enter the article names (Part_1 and Part_2). Here's my modified query. The result is incorrect; I must have made a mistake in my query. Thanks.
- NicoD1 year agoIdeator III
Hello, in a query builder is it possible to have 2 distinct branches, which would allow to have one branch for article 1 and the other for article 2. Thank you
Hello community, I found it and I'll give you the query definition.
In summary, on the same article level, I can search for 4 articles common to a parent article.
Thanks Christopher to your help.
Hello, is it possible to perform a multi-value search in the search variable of the tree grid I created? Currently, I can search multiple columns, but only one value at a time. My search method is *123*. I tried *123*|*456*, but it doesn't work.
Thanks.
