Hi Tim,
If you're a partner there is an updated version of Flow which is distributed with the demo environment. You can find it on the FTP or the partner portal, along with special instructions about loading it.
AJ
Thank you AJ,
The installation process is, however, not very "app-like"! Side-loading, installing certificates, editing the registry, etc...
I'll run through it, but would customers have to do the same or would they be able to use the version off the MS App Store, even with the latest versions of Innovator?
Thank you,
Tim
- asebastian5 years agoCommunity Manager
As of right now, no. We include Aras Flow as part of the Partner Demo Script so that you can show it as an example of ways that Aras Innovator could connect to external custom applications.
- Tim_Beard5 years agoIdeator III
Aha! So more of a concept demonstration. Good to know. I'll pitch it appropriately, then.
