Install Update package
Hi..I want to install update package eg. aras quality management system but it's failed.Below is the log.
2019-04-01 15:29:19,307 [3] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\QMS\11.0.1030\package.config'
2019-04-01 15:29:19,325 [3] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished
2019-04-01 15:29:21,135 [3] ERROR Aras.Tools.ArasUpdateGui.Logger Source file does not exist or could not be found: C:\Program Files (x86)\Aras\Innovator\Client\scripts\include\rev.inc
2019-04-01 15:29:21,138 [3] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Source file does not exist or could not be found: C:\Program Files (x86)\Aras\Innovator\Client\scripts\include\rev.inc
2019-04-01 15:29:21,156 [3] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed
  • Hi izzul,
    I think the issue you're running into is that the Aras Update tool is expecting a different folder for the Install Path than the one that's being provided.
    By default, Aras Innovator is installed to C:\Program Files (x86)\Aras\Innovator\. Also by default, this folder will contain all of the config files (e.g. InnovatorServerConfig.xml, VaultServerConfig.xml, etc.) as well as all of the application folders such as /SelfServiceReporting/, /VaultServer/, and most importantly /Innovator/. The QMS package expects that the install path be this /Innovator/ application folder.
    You should be able to resolve this issue by passing in C:\Program Files (x86)\Aras\Innovator\Innovator\ as the Install Path for the QMS package.
    • Former_Member's avatar
      Hi Chris,
      I have changed the Install Path but still failed to install.Below is the log.
      2019-04-02 12:12:20,711 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\QMS\11.0.1030\package.config'
      2019-04-02 12:12:20,731 [6] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished
      2019-04-02 12:12:20,893 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Variable 'VersionServiceUpdate' is not found in DB.}
      2019-04-02 12:12:20,918 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Variable 'Application Core' is not found in DB.}
      2019-04-02 12:12:20,963 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Application is not exist in Innovator (com.aras.innovator.cmf).}
      2019-04-02 12:12:20,988 [6] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Application is not exist in Innovator (com.aras.innovator.solution.PLM).}
      2019-04-02 12:12:21,016 [6] ERROR Aras.Tools.ArasUpdateGui.Logger HTTP Error
      2019-04-02 12:12:21,018 [6] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: HTTP Error
      2019-04-02 12:12:21,023 [6] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed
  • Hi izzul,
    You used Aras Update Tool hay Import Tool? I think you should Import Tool, Ii will surely succeed
